Hi yall,
I'am trying to shrink two dvd's:
National Security and Bringing down the house.
I use DVD Shrink 3.0 or 2.3 but half way trough I get the following error:
"Recycle redundancy check"
I never get this msg. before.
With other dvd it goes just fine.
It is only these two.
what does this mean and what can I do to get a Image of these movies?
Greets, Mysterio
Rip ALL the files to your HDD with DVD Decrypter and work with files instead of discs
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
thx 4 the reply,
I have tried what you told me but i get the msg that the dvd is copy protected.
what els can I do?Greets, Mysterio -
Did you actally use DVD Decrypter like he said, or did you just try to copy the files?
First try the easiest thing: Wipe off the disk with a lint free cloth. Most of the errors I get when copying a disk are solved just by cleaning it.
If your are willing to buy a great program, try Dvd X Copy Xpress , its 70$, and it will do straight disc to disc copies.. I live by this app. it is well worth the money..
HI yall,
Yes i use DVD Decrypter like he said.
I will try the cean disc solution tomorrow.
Yes DVDxCopy Xpress rules 2 to but even with that it does not work.
DVD Shrink leads the way baby...all the way...Greets, Mysterio -
huh, it doesnt work?, ive been useing this program ever since i got my burner, and it never let me down. ive backed up almost every dvd i own with it, and ive never got a coaster with it.Originally Posted by Mysterio
Problem with DVDShrink
By abba1961 in forum DVD RippingReplies: 3Last Post: 22nd Mar 2010, 02:52 -
DVDshrink problem with a new DVD
By mvp in forum Newbie / General discussionsReplies: 3Last Post: 26th Feb 2008, 14:01 -
Which is better - shrinking with DVDShrink or......
By robertazimmerman in forum DVD RippingReplies: 21Last Post: 4th Feb 2008, 14:12 -
Problem with dvdshrink
By malleus in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2007, 22:03 -
Problem shrinking Freedom Writers
By woodcutter3 in forum DVD RippingReplies: 1Last Post: 4th Jun 2007, 04:00
